2 soundqubed hds3.1 15s 6th order
BadInkKid5150
I'm just not sure how to figure the middle chamber. Do I just design a parallel 6th an double the front chamber to accommodate 2 subwoofers and keep the rear airspace for 1 subwoofer
That is a parallel 6th you just design it as such, you layout the front chamber unmodified and divide the volume of the rear chamber in two and divide port area as well, the rear chamber ports port length need to be adjusted the same way as you adjust every time you use multiple ports in a box design. Honestly no compelling reason to go with that design, if by any chance the rear chambers are not exactly the same size, that can be the source of a lot of trouble. Simple is better every time.
  • Who's Online   0 Members, 0 Anonymous, 1161 Guests (See full list)
