Need enclosure help
Cory2G
First off new to the forum. Sure yall see this sort of question alot.
Hopefully I can get some good feedback.
I got a pair of SA E15 V.4's I have designed an enclosure for but would like if someone could give any advice as I have no access to a better enclosure calculator.
Sorry in advance for the scribblage
Hey Cory, welcome!
Is there a reason why you are drawing it up as two separate chambers/boxes instead of a shared chamber for both subs?
Also, what amplifier are you running?
Either way, I am coming up with the following based on your dimensions pictured:
Net Volume: 3.72 ft^2
Tuning Frequency: 39.76 Hz
Port Area: 64.75 in^2
1997 Chevrolet Cavalier Two 12" DC Audio XL M2'sCrescendo Audio BC5500d
Current Scores: 150+ out the Trunk
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
If you were set on running two separate chambers, the following puts you right around Sundown's suggested numbers:
20H x 20W x 27D
Port Dimensions: 18.5H x 2.75W x 30D
Net Volume: 3.27ft^3
Tuning Frequency: 34.19Hz (The tuning frequency you requested above, Sundown suggests 32Hz tuning for these E15's)
Port Area: 50.88in^2
If you built two of these and joined them together as it looks like you were trying to do above, you'd only need 40W x 27D for the top and bottom pieces.
Avalanche are subs / port forward box placed at the mid gate location, so you are fine.
Box specs per driver is 3.25 net @32Hz with 52 square inches of port area so since there are two subs your box specs should be:
 6.5 cubic feet net @32Hz with 104 square inches of port area.
Ideally you want to seal off the trunk for better results.
So let me know any questions.
  • Who's Online   1 Member, 0 Anonymous, 1496 Guests (See full list)
