Alex41900 Posted December 22, 2022 Report Posted December 22, 2022 Hello everyone so I was impatient an mixed a down4sound 6.0 lto battery and a lead acid an everything was great my voltage was consistent at what it should be unless I pushed on it real hard which obvious but it would hold where it should but one day I was driving with amp turned off and no music my battery light turned on and my clusters are going crazy so I pulled over pop the hood and the front battery it was hissing/venting it even shot the vent cap right off turns out my cluster fried my ECU fried an my fuse box I don’t know what caused it I was wondering if it was from mixing them or what
Kyblack76 Posted December 24, 2022 Report Posted December 24, 2022 Designed to work directly inline with stock charging voltages (No voltage-boosting needed to achieve optimal results). Can be paired with regular 12v / non-lithium batteries with no issues. 14.8v Maximum Charge voltage (DO NOT EXCEED THIS OR BATTERY DAMAGE / FAILURE COULD OCCUR). SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
