I've never designed a 4th order but I'm sure you can get some help from here and elsewhere.
Since you can't fold down your seats I think it'd be better with all the output coming through the rear deck instead of just the port.
Just a thought.
yeah i do need to get that shit threw the rear deck
good bandpasses are hard to design and build >=(
Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
Posted Image
Posted Image
just do that.
subs fwd, sealed off with vents through the rear deck.
-Drew
what song is playin in the video's
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
Shine Cause I Grind by Crime Mob
-Drew
uhoh_45 said:
If I decide to puss out and do a regular ported box I will do two 12 btl's but if I decide to do the blow threw I will do two 15's btl witch Im really leaning towards a blow threw
Need to make some last measurements before I order 15's what about cubes should I use I was thinking 8 after displacement tuned at 33 hertz. Would it be alrite to use 4 aero ports becuase I think it would look cleaner and fit better on the rear deck
people never listen :unsure: :unsure:
i decided to do the 2 15's firing and ported threw the rear deck and was unsure of cubes and tunning. what was there to listen too.
