All U T4K users
CUT BUDDY
Thats cuz sonic electronic is using the ol t3k fuse rating. The T4k has a 500amp fuse....there is no way ur gonna get 4k + rms outta a 300amp fuse.....u might get up to about 3400 but not 4k. Iv seen meades and his came with 500amp fuses.....http://www.stevemeadedesigns.com/forums/index.php?topic=297.0
then explain how the  t15k one pulls around 375 amps
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
on the t15k go read up on the technology....also as the install progresses ill be a REAL judge on if this amp does what it says it will do.  I scaled back the caddy plans, i was going to do 10 batterys just for the hell of it and because it cant hurt right?  Nahh my RF "contact" says 2 batterys at the most....so when this is in full wang-age ill let you guys know if its doin what its supposed to ;)
On my amps i have 1/0 going to each T4000.1bd.  The runs are about 6 feet long each from the batts to the amps and are doing JUST fine.  Yes the T4k has a 500amp fuse.
Follow my Tweet (Twitter)
So I take it that they'll still get 4k even off 1/0 cuz of the efficiency and extra power from the batts?
00114-1.jpgTEAM MechMan Alternators
i think the length of the wire has as much to do with it carrying the load of a 4,000 watt amp as anything.  My runs are fairly short and all thats required is a 1/0 wire.  Of course if there is a 30 foot run it may start causing problems....
Put it this way, do i not look like i got it handled :D
meade, did u ever get that outkast song I sent u?
ummm im not sure....
ok thanks for clearing that up on my part. guess someone needs to write sonic e :D
Also sonic e might be going off of the manual.  The manual says its (2) 300 A fuses stacked when its actually that (1) 500 A fuse.
Member since 25 Jun 2006
2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
  • Who's Online   0 Members, 0 Anonymous, 404 Guests (See full list)
