Does anyone know how a company makes impedance differnces of voice coils? Like how you can have .35,.5, .75, 1 , 2, 4 etc. Like how do they make it different ohms? Im not talking about how to wire them differnt to get a lower or higher ohm but the subs voice coil themselves from factory.
I believe its the amount of wire that they use to make the voice coil.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Look at it like a coil the more windings the higher impedance. The less amount of windings the lower the imedance.
x2 and wire thickness
Head Unit: Pioneer DEH-P4050UB
Subs: 2 Pioneer Premier 12" ts-w3004spls
Sub box: 3.2ft3 tuned to 35hz
Sub Amp: SoundMagus DK 1800
Speaker Amp: Rockford Fosgate 200a4 Bridged to fronts
Front Speakers: DLS MS5A components
2 gauge power & ground
Hmmmm, But wouldent less coil make heat dissapation harder and handle less power? Usually larger the coils in diamter the higher power handleing.
Imagine takeing your speaker leads and shorting them together. Now take a wire and wrap it perfectly around something evenly then stick an ohm meter on it. More windings more resistance.
I'm pretty sure thats how it works.
I might be wrong on this one.
  • Who's Online   0 Members, 0 Anonymous, 1000 Guests (See full list)
