Guest beatitouttheframe Posted December 7, 2006 Report Share Posted December 7, 2006 i just got an al yes al not jl audio,al audio amp 820watts and i love it it beats like theres no tomarrow anyone heard of them? Quote Link to comment Share on other sites More sharing options...
AI James Posted December 8, 2006 Report Share Posted December 8, 2006 never heard of them, post a pic if you can Quote Link to comment Share on other sites More sharing options...
Guest beatitouttheframe Posted December 8, 2006 Report Share Posted December 8, 2006 ok Quote Link to comment Share on other sites More sharing options...
Guest beatitouttheframe Posted December 8, 2006 Report Share Posted December 8, 2006 http://s143.photobucket.com/albums/r142/be...ype=local if u look on the second padge ur will see the amp and subs not a very good pic but my camera died this morning Quote Link to comment Share on other sites More sharing options...
AI James Posted December 8, 2006 Report Share Posted December 8, 2006 this pic is a violation of car audio laws ROFL Quote Link to comment Share on other sites More sharing options...
Guest beatitouttheframe Posted December 8, 2006 Report Share Posted December 8, 2006 Quote Link to comment Share on other sites More sharing options...
Guest beatitouttheframe Posted December 8, 2006 Report Share Posted December 8, 2006 lol yea yea i kno somone stole my highs lol i had no choice Quote Link to comment Share on other sites More sharing options...
AI James Posted December 8, 2006 Report Share Posted December 8, 2006 i honestly cant even tell what that is man Quote Link to comment Share on other sites More sharing options...
Guest beatitouttheframe Posted December 8, 2006 Report Share Posted December 8, 2006 lol i kno its a bad pick its a al audio 820w amp ill find a pic on there wedsite brb Quote Link to comment Share on other sites More sharing options...
Guest beatitouttheframe Posted December 8, 2006 Report Share Posted December 8, 2006 APC602 • 2 Channel Mosfet Power Amplifier • PWM Controlled DC to DC Switching Power Supply • 2 OHM Stable Stereo • Built-in Remote Control Jack (Remote Sold Separately) • Chrome Top Plate • Built-in Cooling Fan with Gray Grill • Bridgeable (4 OHM) • Tri-Mode Capable • Built-in Variable High Pass Filter: 50Hz - 500Hz • Built-in Variable Low Pass Filter: 50Hz - 150Hz • Line In / Line Out RCA Jack • Channel Separation: Better than 60dB • 0.01% THD (4 OHM) • Signal to Noise Ratio: 105dB • Speaker and Thermal Protection Circuit • Max Power: 300W x 2 Ch • RMS Power: 150W x 2 Ch • Dimensions: 10.4” (W) x 2.2” (H) x 7.9” (D) ALR-100 Optional Remote Sold Separately APC802 • 2 Channel Mosfet Power Amplifier • PWM Controlled DC to DC Switching Power Supply • 2 OHM Stable Stereo • Built-in Remote Control Jack (Remote Sold Separately) • Chrome Top Plate • Built-in Cooling Fan with Gray Grill • Bridgeable (4 OHM) • Tri-Mode Capable • Built-in Variable High Pass Filter: 50Hz - 500Hz • Built-in Variable Low Pass Filter: 50Hz - 150Hz • Line In / Line Out RCA Jack • Channel Separation: Better than 60dB • 0.01% THD (4 OHM) • Signal to Noise Ratio: 105dB • Speaker and Thermal Protection Circuit • Max Power: 400W x 2 Ch • RMS Power: 200W x 2 Ch • Dimensions: 10.4” (W) x 2.2” (H) x 10.7” (D) ALR-100 Optional Remote Sold Separately APC1004 • 4 Channel Mosfet Power Amplifier • PWM Controlled DC to DC Switching Power Supply • 2 OHM Stable Stereo • Built-in Remote Control Jack (Remote Sold Separately) • Chrome Top Plate • Built-in Cooling Fan with Gray Grill • Bridgeable (4 OHM) • Tri-Mode Capable • Built-in Variable High Pass Filter: 50Hz - 500Hz • Built-in Variable Low Pass Filter: 50Hz - 150Hz • Line In / Line Out RCA Jack • Channel Separation: Better than 60dB • 0.01% THD (4 OHM) • Signal to Noise Ratio: 105dB • Speaker and Thermal Protection Circuit • Max Power: 250W x 4 Ch • RMS Power: 125W x 4 Ch • Dimensions: 10.4” (W) x 2.2” (H) x 11.8” (D) ALR-100 Optional Remote Sold Separately APC1202 • 2 Channel Mosfet Power Amplifier • PWM Controlled DC to DC Switching Power Supply • 2 OHM Stable Stereo • Built-in Remote Control Jack (Remote Sold Separately) • Chrome Top Plate • Built-in Cooling Fan with Gray Grill • Bridgeable (4 OHM) • Tri-Mode Capable • Built-in Variable High Pass Filter: 50Hz - 500Hz • Built-in Variable Low Pass Filter: 50Hz - 150Hz • Line In / Line Out RCA Jack • Channel Separation: Better than 60dB • 0.01% THD (4 OHM) • Signal to Noise Ratio: 105dB • Speaker and Thermal Protection Circuit • Max Power: 600W x 2 Ch • RMS Power: 300W x 2 Ch • Dimensions: 10.4” (W) x 2.2” (H) x 15” (D) ALR-100 Optional Remote Sold Separately APC1802 • 2 Channel Mosfet Power Amplifier • PWM Controlled DC to DC Switching Power Supply • 2 OHM Stable Stereo • Built-in Remote Control Jack (Remote Sold Separately) • Chrome Top Plate • Built-in Cooling Fan with Gray Grill • Bridgeable (4 OHM) • Tri-Mode Capable • Built-in Variable High Pass Filter: 50Hz - 500Hz • Built-in Variable Low Pass Filter: 50Hz - 150Hz • Line In / Line Out RCA Jack • Channel Separation: Better than 60dB • 0.01% THD (4 OHM) ALR-100 Optional Remote Sold Separately APC802 • 2 Channel Mosfet Power Amplifier • PWM Controlled DC to DC Switching Power Supply • 2 OHM Stable Stereo • Built-in Remote Control Jack (Remote Sold Separately) • Chrome Top Plate • Built-in Cooling Fan with Gray Grill • Bridgeable (4 OHM) • Tri-Mode Capable • Built-in Variable High Pass Filter: 50Hz - 500Hz • Built-in Variable Low Pass Filter: 50Hz - 150Hz • Line In / Line Out RCA Jack • Channel Separation: Better than 60dB • 0.01% THD (4 OHM) • Signal to Noise Ratio: 105dB • Speaker and Thermal Protection Circuit • Max Power: 400W x 2 Ch • RMS Power: 200W x 2 Ch • a few specs Quote Link to comment Share on other sites More sharing options...
