Guest beatitouttheframe Posted December 7, 2006 Report Posted December 7, 2006 i just got an al yes al not jl audio,al audio amp 820watts and i love it it beats like theres no tomarrow anyone heard of them? Quote
AI James Posted December 8, 2006 Report Posted December 8, 2006 never heard of them, post a pic if you can Quote
Guest beatitouttheframe Posted December 8, 2006 Report Posted December 8, 2006 http://s143.photobucket.com/albums/r142/be...ype=local if u look on the second padge ur will see the amp and subs not a very good pic but my camera died this morning Quote
AI James Posted December 8, 2006 Report Posted December 8, 2006 this pic is a violation of car audio laws ROFL Quote
Guest beatitouttheframe Posted December 8, 2006 Report Posted December 8, 2006 lol yea yea i kno somone stole my highs lol i had no choice Quote
AI James Posted December 8, 2006 Report Posted December 8, 2006 i honestly cant even tell what that is man Quote
Guest beatitouttheframe Posted December 8, 2006 Report Posted December 8, 2006 lol i kno its a bad pick its a al audio 820w amp ill find a pic on there wedsite brb Quote
Guest beatitouttheframe Posted December 8, 2006 Report Posted December 8, 2006 APC602 • 2 Channel Mosfet Power Amplifier • PWM Controlled DC to DC Switching Power Supply • 2 OHM Stable Stereo • Built-in Remote Control Jack (Remote Sold Separately) • Chrome Top Plate • Built-in Cooling Fan with Gray Grill • Bridgeable (4 OHM) • Tri-Mode Capable • Built-in Variable High Pass Filter: 50Hz - 500Hz • Built-in Variable Low Pass Filter: 50Hz - 150Hz • Line In / Line Out RCA Jack • Channel Separation: Better than 60dB • 0.01% THD (4 OHM) • Signal to Noise Ratio: 105dB • Speaker and Thermal Protection Circuit • Max Power: 300W x 2 Ch • RMS Power: 150W x 2 Ch • Dimensions: 10.4” (W) x 2.2” (H) x 7.9” (D) ALR-100 Optional Remote Sold Separately APC802 • 2 Channel Mosfet Power Amplifier • PWM Controlled DC to DC Switching Power Supply • 2 OHM Stable Stereo • Built-in Remote Control Jack (Remote Sold Separately) • Chrome Top Plate • Built-in Cooling Fan with Gray Grill • Bridgeable (4 OHM) • Tri-Mode Capable • Built-in Variable High Pass Filter: 50Hz - 500Hz • Built-in Variable Low Pass Filter: 50Hz - 150Hz • Line In / Line Out RCA Jack • Channel Separation: Better than 60dB • 0.01% THD (4 OHM) • Signal to Noise Ratio: 105dB • Speaker and Thermal Protection Circuit • Max Power: 400W x 2 Ch • RMS Power: 200W x 2 Ch • Dimensions: 10.4” (W) x 2.2” (H) x 10.7” (D) ALR-100 Optional Remote Sold Separately APC1004 • 4 Channel Mosfet Power Amplifier • PWM Controlled DC to DC Switching Power Supply • 2 OHM Stable Stereo • Built-in Remote Control Jack (Remote Sold Separately) • Chrome Top Plate • Built-in Cooling Fan with Gray Grill • Bridgeable (4 OHM) • Tri-Mode Capable • Built-in Variable High Pass Filter: 50Hz - 500Hz • Built-in Variable Low Pass Filter: 50Hz - 150Hz • Line In / Line Out RCA Jack • Channel Separation: Better than 60dB • 0.01% THD (4 OHM) • Signal to Noise Ratio: 105dB • Speaker and Thermal Protection Circuit • Max Power: 250W x 4 Ch • RMS Power: 125W x 4 Ch • Dimensions: 10.4” (W) x 2.2” (H) x 11.8” (D) ALR-100 Optional Remote Sold Separately APC1202 • 2 Channel Mosfet Power Amplifier • PWM Controlled DC to DC Switching Power Supply • 2 OHM Stable Stereo • Built-in Remote Control Jack (Remote Sold Separately) • Chrome Top Plate • Built-in Cooling Fan with Gray Grill • Bridgeable (4 OHM) • Tri-Mode Capable • Built-in Variable High Pass Filter: 50Hz - 500Hz • Built-in Variable Low Pass Filter: 50Hz - 150Hz • Line In / Line Out RCA Jack • Channel Separation: Better than 60dB • 0.01% THD (4 OHM) • Signal to Noise Ratio: 105dB • Speaker and Thermal Protection Circuit • Max Power: 600W x 2 Ch • RMS Power: 300W x 2 Ch • Dimensions: 10.4” (W) x 2.2” (H) x 15” (D) ALR-100 Optional Remote Sold Separately APC1802 • 2 Channel Mosfet Power Amplifier • PWM Controlled DC to DC Switching Power Supply • 2 OHM Stable Stereo • Built-in Remote Control Jack (Remote Sold Separately) • Chrome Top Plate • Built-in Cooling Fan with Gray Grill • Bridgeable (4 OHM) • Tri-Mode Capable • Built-in Variable High Pass Filter: 50Hz - 500Hz • Built-in Variable Low Pass Filter: 50Hz - 150Hz • Line In / Line Out RCA Jack • Channel Separation: Better than 60dB • 0.01% THD (4 OHM) ALR-100 Optional Remote Sold Separately APC802 • 2 Channel Mosfet Power Amplifier • PWM Controlled DC to DC Switching Power Supply • 2 OHM Stable Stereo • Built-in Remote Control Jack (Remote Sold Separately) • Chrome Top Plate • Built-in Cooling Fan with Gray Grill • Bridgeable (4 OHM) • Tri-Mode Capable • Built-in Variable High Pass Filter: 50Hz - 500Hz • Built-in Variable Low Pass Filter: 50Hz - 150Hz • Line In / Line Out RCA Jack • Channel Separation: Better than 60dB • 0.01% THD (4 OHM) • Signal to Noise Ratio: 105dB • Speaker and Thermal Protection Circuit • Max Power: 400W x 2 Ch • RMS Power: 200W x 2 Ch • a few specs Quote
