ok my brain hurts now :wacko:
DC.jpgDC POWER
Im trying to piece together my own active 3way using a AudioControl DQXS electronic eq/processor (top of the line sh%t). It has outputs for Sub, Midbass, midrange/front lowpass, and front highpass. My question is are coaxial speakers ok to use as a midrange? the midrange area of a setup is were your vocals, some piano notes and snares come from. anywhere between 300Hz-2000Hz (maybe a lil higher in the frequency range).
Edited by CUT BUDDY
00114-1.jpgTEAM MechMan Alternators
why not just get a mid? i think that kinda defeats the purpose of going active
DC.jpgDC POWER
these were the ones i bought when i was was thinking of going active
http://mach5audio.com/zen/index.php?main_p...products_id=183
not very expensive at all, or maybe the dayton 180
http://www.partsexpress.com/pe/showdetl.cf...tnumber=295-374
DC.jpgDC POWER
those mach 5's (6.5") look good. May be an option for midbass but the thread is about small midranges. I need some good 4" or 3.5" midranges which is why I was looking at coaxials. Anything like a 6.5" or 8", I would use strictly for a midbass 80Hz-300Hz.
ok finally made up my mind. Tell me what u think.....cost effective and should sound pretty good.
2 pairs of each.
http://www.sonicelectronix.com/item_2316_Visonik+VT1229.html
http://www.partsexpress.com/pe/showdetl.cf...tnumber=295-378
http://www.partsexpress.com/pe/showdetl.cf...tnumber=290-307
a 4"with a tweet in the A-pillars, a 4" and tweet in the factory door openings at knee level, and 2-6.5" at the bottom of each door. Think that will keep up with my BTL 12s?
Edited by CUT BUDDY
