01 sentra b pillar wall for 5x 12's
finally got started on it heres some pics form today tipping out the trunk build and starting to mock panels up
front baffle will be tripple thick with dbl layer everywere else
inner panels are a lil bit cheaper ply with the outer layers being 13 ply
358848452_248738114679144_6601258265794674613_n.thumb.jpg.92c1d1b8db898692e3bf82538a5a981c.jpg364038949_817822536599072_3226681892327960418_n.thumb.jpg.98003a2b4267ce4c8600b70732e51b02.jpg363362285_817802496601076_5934218662935184950_n.thumb.jpg.f1ef29040f64c43880ba864995a94c41.jpg
363364083_817822609932398_6412537395994543449_n.thumb.jpg.6249f3247984d45e8d0490f53de5b412.jpg
layout is going to be 3 subs across the top , and 2 on the bottoms on left and right of the baffle with a 225sqin swapable slot port tuned for 28hz for daily use and more then likley 45hz for burping
got the excess cut fromt he corners and had to call it a night ran out of daylight , i have 2 panels to install in the top of the box tommorow morning and then i can work on fiberglassing and sealing the inside before i put the outser layers on
progress is slow but i got the port cut and in today for testing and 3 out of the 5 sub amps installed  its enough for some low power testing /checking making sure the enclosure doesnt have anything loose etc
hopefully ill have enough time this weekend to get all 5 wired up and playing
  • Like (+1 Rep) 3
  • Who's Online   1 Member, 0 Anonymous, 1389 Guests (See full list)
