Banditnib Posted August 26, 2023 Report Posted August 26, 2023 Hello, I have a taramps 5k md 1 ohm. I’m setting up double runs of 1/0 gauge. One thing is confusing me. The amps manual states that the recommended fuse size is 250a. If I have two runs what size fuse would I put on the power wires going from second battery to amplifier? Any help would be appreciated! Here’s my set up. 320 mechman alternator 2 XS power D5100r’s All 1/0 wiring with all power wires fused. Lc2i for amp signal.
Joe X Posted August 26, 2023 Report Posted August 26, 2023 Each of the two lines ideally should have a 125A fuse if the max current draw is 250A.
Banditnib Posted August 26, 2023 Author Report Posted August 26, 2023 Awesome thank you! I had a hard time finding a straight answer.
