Subs/ enclosure questions
I’m new to forums , hope on the right thread .
I have a 2015 Ford F150 supercrew with the 2.5” seat lift . I’m running to 2 RF T1500 Bdcp. I’m in limbo about running 2 Sundown U 10s or 4 Sundown U 8s . If I go 4 8s I’ll have around .75 sqft per sub after displacement . Box will be tuned@ 32 hz with 42 sq/in of port area . Does this sound right
You are using max net volume and will go above rated power, I'd use at least the 12 square inches of port area per driver, Haven't modeled those subs yet though.
Hi there - Thanks for  responding  Sundown recommends 12 - 16 inches of  port area per sub. So do I need at least 48 sq/in of port area.
Do you recommend maybe  trying area port or stick with slot port .Just did some math 48” sq/in port area tuned to 32hz  port length is around 33.39” long  does that look right . Thanks again  Happy Thanksgiving
You're welcome, 48 square inches of port area should be fine, the box should be 0.75 x 4 = 3 cubic feet net, A 3 common wall slot port 33.4 inches in length would tune you to about 33Hz.
  • Who's Online   0 Members, 0 Anonymous, 930 Guests (See full list)
