Enclosure for DD Audio Sl 612 D2?
Kallior
So i have been trying to make my own ported/vented enclosure for my DD Audio 612 sl D2 woofer but I don't have prior experience in this. I have GAS PRO 1001.1 amplifier for it and I plan to run it at 1 ohms. So do eny of you know how large of an enclosure should I make for it and what sized and lenght port should I use? Is 50l enclosure and 3 inch wide and 20cm  long port too small?
Let me know what vehicle are you using and why did you pick a shallow mount sub and not a regular one.
regular sized woofer and box didn't fit in my previouse car. I have seat exeo 2.0tdi wagon with back seats of now.  But  the old box broke so I need to make a new one for it. and i don't have the money to by a regular sized woofer right now. I plan to make the new box form 25 mm thick mdf board
First determine the box size you are comfortable with I say the 1.75 net is fine given your amp is 1000W RMS and your sub is 600W RMS, large box size means you will need to run it a little more carefully and set your subsonic filter higher.
For 1.75 net a 4" port needs to be 14.7" long for a 33Hz tuning.
Said that a 4" round port is barely large enough for 600W power if you push more power you may get port noise.
Ideally a slot port with 20 square inches of port area is needed to get the best out of the sub in a ported enclosure.
  • Who's Online   0 Members, 0 Anonymous, 1040 Guests (See full list)
