Hey guys, hope all is well.
Ill get right into it. I did a small upgrade in the car and added a set of Jl Audio c1s 6.5 with a crappy headunit replacement because it was as far as my budget could go. No amplifiers. the head unit is https://www.elektramobileaudio.com/mhu-32bt-head-unit/.
This is where its gets tricky, so my brother had a pair of the jl C2's 6.5 and he loaned me the crossovers as he wasn't using it. I then replaced the crappy crossovers that came with the c1 and am currently using the c1 speakers with the c2 crossovers. The problem with the headunit is that it has no crossover setting, nor hpf/lpf setting, it basically just has an EQ.
A couple questions
1. Does the c1 midbass speaker have a natural roll off for the highpass that i don't need a highpass filter. If so, what's the average roll off and at what order for yall with the experience.
2. Given i cant set crossover with the head unit, should i simply EQ out the lower end or will the speaker naturally roll off.
Thanks in advance
