I have a Skar RP.1500 amp and I am not receiving a signal to the dd1 from it. Setting my Sony XAV-AX7000 headunit subwoofer gain works fine. Could it possibly be that i have a Low Pass Crossover on the headunit set to 100hz? The only reason i think it isnt is because I set the headunit gain with the LPF on. So could there be another solution?
Edited by Khypercuhh
you are suposed to set crossovers after setting gain. in the manual of the dd-1 it tells you to disable any crossovers before setting gain. try turning off crossovers and redo the tuning
This page is crispy_chick3n approved.
© crispy_chick3n inc
