Single svr-15d2 box built attempt
15" box build attempt pls rip apart TY
Hello! Well here's my first attempt at building a box for my svr15d2 skar sub linked below. My main question is really if it seems like it's properly tuned and displacements are correct. It seems the sub from the manufacturer wants;
Recommended Ported Volume: 3.00 ~ 3.45 ft³
Recommended Tuning Frequency: 32 Hz
Recommended Port Area: 38.75 in²
Cut-out Diameter    14.32"
Mounting Depth    7.23"
Total Height    8.50"
Outside Diameter    15.51"
Magnet Diameter    6.93"
Displacement 0.251
If anyone has some time to rip into it or give me the green light to build it if it's good. Or if you've built a single svr15 skar box that is better then this hit me up! Thank you all really appreciated!!!!
https://subbox.pro/en/b/OqDEppcB0
Box seems to line up with Skar's specs... Wood thickness, 3/4" is minimum recommended, and doubling up on front baffle for better reinforcement.
Box is on the bigger end, which is fine if you're either powering to RMS or under-powering it.
