On 4/3/2025 at 9:21 AM, Harobmx21 said:
I guess i could use channels 1 & 2 for the the npx with crossover at 100hz and just merge the connections at the amp. An run another line to each door for the spxs using channel 3 & 4 with crossover at 50hz.
This is what I was suggesting you above, you get actually more power per driver and you don't have to buy a crossover to use as high pass filter, I actually don't know if the input impedance of the passive crossover gets affect by only using the high pass filter and leaving open the low pas filter
