JefferyF Posted April 22, 2025 Report Posted April 22, 2025 This is my first time reconing a sub with a bolt in spider, do I glue it and bolt it as well and if indont have the correct shims what can I do?
crispy_chick3n Posted April 22, 2025 Report Posted April 22, 2025 you'll know if it needs to be glued when you take the blown cone out of your sub. if it has glue from the factory, put glue back on it. as for the shims you can use printer paper slid in between the coil and pole from the top. gently slide paper in evenly around a couple sheets at a time until you can't slide any more in. just make sure its evenly placed around. if you place a sheet in and there is a spot on one side where the paper doesn't cover, the middle of the next sheet should be on that gap. keep doing that until you fill it up and it should be spaced evenly. make sure the glue is cured fully, or the bolts are tightened properly before removing the paper and you'll be good to go. This page is crispy_chick3n approved. © crispy_chick3n inc
