Amp Gain set/installed with EQ bass set at 10 out 12
My friend got a system installed (amp $ Sub) and the person told them to never raise the HU up higher than 10.
I told him typically you flat the EQ when setting gain.
My first thought it was to fix the roll-off, but I think the plan was the allow the front factory door speakers match the bass output.
Is this okay, can the gain be set safely with the bass EQ up ?
The door speakers do not distort at the bass being set at 10 when at 3/4 volume.
400 watt 10 in sub, he now wants a 12 in 600 watt sub.
if the bass eq is set before setting gain you can still tune it to be ok, it's just going to distort at a lower volume which might make the system sound unbalanced. generally, you want to tune with eq flat so as not to add distortion into the input side of the amp. amplifiers will only amplify the signal they are being fed. if that happens to be a distorted signal, they will only make it worse.
This page is crispy_chick3n approved.
© crispy_chick3n inc
