i have a problem with this setup, my amp just cuts off, after running it for awhile. i have to restart the HU and everything would be back on. its driving me crazy, i switched out thye amp to a 750x1 kicker and everything is fine, is something wrong with my amp? i asked a couple of my friends and they said it happened to them before too, is there a solution to this?
Amp is over heating.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
thats what i thought at first, i pulled out the sub and its wired to 3ohm. the amp is rated at 750 at 4ohms and 1500 at 2ohms. so i figure since the sub is at 3ohm, the amp should be pushing out a little under 1100. any idea on how to keep it cool? its not sealed away or anything.
its starting to get alot warmer out and of course you could try to mount you amp somwhere else or even get a fan from radio shack and see if you could see dif results. if your runnin at 3 ohms thats weird for that amp to overheat.
Youtube.com/J Hutch22
years ago when the W7 first came out, i had a potna who ran the 12w7 and a RF 1501d, man it slammed hard. he never had a problem .
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
i was wondering, could it also be that my amp is not getting enough power?
what size power wire are you running?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 673 Guests (See full list)
