The mojo 3000.1 will drive 4 of the mojo pro 12 and you would need to buy electrical upgrades for your car to run that amp which can be very expensive.
If you are going to use 1 or 2 subs you probably don't need so much power, you still can use it but you are paying for more capacity than you need.
Ok I do have high output alt and big 3 with 0ga wire. Is there a Amy you could recommend that would work good and not overheat I tend to list to it on long drives I have a soar ap1500 on it now and it will shut off and back on after a while. Thanks
If your amp does everything right except for overheating is most likely because of installation/operation error, said that if you continue using it like that it will fail without a doubt, common causes of overheating include:
- bad grounding / wiring
- low impedance loading
- low input voltage
- clipping
- subsonic filter not properly set
- poor ventilation, sometimes you can install fans if the amp needs to be in a poorly ventilated location
Also is very possible that if those issues are not corrected a new amp will also overheat, so fix or have someone fix the issues and if the system is not playing loud enough then yes get a better amp, more subs or whatever.
Since you have a single 1/0 wire it could source up to a 2K or so amp, if you get an amp with multiple 1/0 inputs you will probably need to upgrade your full electrical system too.
Edited by Joe X
  • Who's Online   0 Members, 0 Anonymous, 455 Guests (See full list)
