so i cant get my 1/0 wire to fit in the terminal... any tricks to this.. i get all this loose shit ... it just seems like its the wrong size.. but its what came with the kit
any help?
and also the wires dont seem to fit in the amp either.... any suggestions for that while we're at it.
sorry im a noob. :blink::unsure:
you ain't been bizzy til you've been wit jizzy.
Vehicle:: 2005 Saturn Ion
Headunit:: Jensen 9312HD
Speakers:: RE SE Coaxials
Subwoofer(s):: (2) 15" RE SEs
Amplifier(s):: Audiopipe AP1500.1D
Audiopipe AP1504
Enclosure:: Sealed
Wire: KNU KONCEPTZ 1/0
Battery:: Kinetik HC600
you could try to cut a few strands neatly out. it will shrink it a bit. or make a clean cut start with fresh wire and sort of pinch it towards the bottom and work them in from there. its hard to explain lol but basically if you strip it back about a half inch and squeeze it and work it you should be fine.
that looks WAY off. your going to have to trim all the extra off if you want to use that ring.
-Drew
uhoh_45 said:
IS that knukonceptz wire ... if so i had the same problem with my 8 gauge i used for my speaker wire .it just seemed to big and my 8 gauge didnt even fit in my amp which had 8 gauge terminals
1999 grand prix gt
kenwood x994 head unit
1/0 big 3 all shok industry single run to the back
New mid/highs coming not sure what
Soundqubed q2200d at .5 (have)
2 soundqubed hdc3 12s (have)
New box to be built.. sealed firing forward (yet to be designed)
200 amp alt not sure exact size or manufactor xs power batts
if you look at the second photo tho you can compare the terminal to the insulated wire. it looks like he twisted it and when you do that it generally bulks it up.
i kinda screwed the terminal on but it didnt go on... so it turned out twisted. but ill just start fresh. try it again
Audiopipe AP1504
Enclosure:: Sealed
yeah its knuknoceptz 1/0
Audiopipe AP1504
Enclosure:: Sealed
  • Who's Online   0 Members, 0 Anonymous, 1072 Guests (See full list)
