I am trying to find the most inexpensive battery to run the system I am running. Has to be able to stick with about 5000w of power. All I have right now is a 10 farad capacitor. Let get some suggestions guys
Howard
A.K.A.- Ol' Mater
Current systems
Speakers:
-2 15" Kicker Comp VR
-4 15" Lanzar ProMax
-2 Kicker comp 6.5's
-4 infinity tweeters
Amps:
-1 HiFonics 750w mono
-1 Kicker 550.1
-1 Lanzar Vibe 2ch 2000w
-1 Legacy Predator 2ch 2000w
Items I have bought for new builds:
-2 Kicker Solo X 18's
-2 Kicker Solobaric L7 15's
-2 HiFonics Xx Goliath 5000w Monoblock Ultra D class
5000w is no joke, you need to upgrade your alt, upgrade your stock batt and put a couple of big batts in the back. also big 3.
Guest aseanj52
Is that 5000 watts RMS or 5000 watts peak power? Cause there is a large difference between the two.
See I have no idea how to measure exactly how many batteries I will need to power it. I am estimating my RMS wattage usage at around 4k-5k at all times. I am running 1 guage from the front to the rear and I plan on running a distrubution block to 4 amps with 4 guage. I just have to figure out how many batteries I will need and what kind I should use. Also is the 4 guage wiring overdoing it?
Howard
A.K.A.- Ol' Mater
Current systems
Speakers:
Amps:
-1 Kicker 550.1
its better if you use 0/1 gauge because i assume you will run 1k watts rms per amp?
you can just estimate, like the powermaster and the kinetik series, their model numbers can give an ballpark figure on how many watts it can run.
kinetik hc2400 (2.4k watts) - just an example.
and have 0/1 gauge at least all throughout
See that is the thing. 2 channels are running 2k each and then 2 channels are 500w each and those are for the mids and highs. It is gonna take me forever to figure out how to wire this damn thing correctly lol
Howard
A.K.A.- Ol' Mater
Current systems
Speakers:
Amps:
-1 Kicker 550.1
Just tell me what amps you are running....b/c your honestly making 0 sense. :wacko:
edit: and the ohm load.
O yeah and kinetik has a calculator on there site to calculate batteries, also there is no point to get all these batteries if you don't have the alt to charge them.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
my suggrestion
220-260amp alt something that does around 165amps at idle
2 runs of 0 gauge wiring
3 power master d3100 batteries in the back
1 power master d2400 battery in front in place of stock battery
  • Who's Online   0 Members, 0 Anonymous, 1403 Guests (See full list)
