NightCrawler Posted June 9, 2008 Report Posted June 9, 2008 i have the 4 alpine type r's just finished the box for them now i need to decide on what 2 amps i should go for and how many watts i will need, each sub is 500 watts rms and 4 ohms 1000 watts max what do you guys think i should run ?
NightCrawler Posted June 9, 2008 Author Report Posted June 9, 2008 how much $$ can you spend on it? about 6-8 hundred right max right now
Stephen Posted June 9, 2008 Report Posted June 9, 2008 are they d2 or d4 edit: cant read. I say a pair of RF t1000's in master/slave you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
A&W ROOTBEER Posted June 9, 2008 Report Posted June 9, 2008 i suggest a kicker zx2500.1 does 2500 watts into 2ohm which is what that sub configuration gives you, you can find it on ebay for about $625 brand new..
hotshot27 Posted June 9, 2008 Report Posted June 9, 2008 i suggest a kicker zx2500.1 does 2500 watts into 2ohm which is what that sub configuration gives you, you can find it on ebay for about $625 brand new.. edit: nevermind, spoke before i thought, would be a good amp Current Setup: Factory HU with LOC mids/highs-Insignia components Sub- E8 in bass tube Amp- sae-1200d Show Setup: HU-Sony MEX-1HD (brings massive respect for sony) fronts - Infinity Kappa perfect comps rears- Infinity Kappa coax mid/high amp - Autotek 5600 Subs - 2 RE SE 15's Sub Amps - 2xSAE-1200D Box - 5cubes sealed Wire- Lots of Knu 1/0 SECOND SKIN
NightCrawler Posted June 9, 2008 Author Report Posted June 9, 2008 are they d2 or d4edit: cant read. I say a pair of RF t1000's in master/slave they are d4s
