What vehicle is this going in?
98 Grand AM
2 MAW15's
Cadence 1000D
Infinity Reference 6022's
Blankput Tweeters and Infinity 4x6's with tweeters
Powered by a US Acoustic USB4085
1 Rockford 1Farad Caps and a 200 amp ALT
  • 1 month later...
You could make a box and use AeroPorts to change the length and or the ports for spl or low daily
What i did was made a box. Then i made three holes for the ports. Then i took some pvc pipe couplings and measured the depth of it. I took that number and added the thickness of the wood to it. Then i took a 10ft pvc pipe and cut the length i had just calculated. I put the coupling on the small piece i cut out and stuck in the hole. The port sits flush with wood.(ports are shooting outside of the box) Then i took the total port length for my ports and subtracted what i had already cut and put that on the other end of the coupling. I now got a box tuned to 30Hz. Then when i compete i just switch the ports out with the shorter ports i have. Theres prolly an easier and better way but this works.
  • 1 month later...
aero ports ftmfw!
Bass junkie for life!
99 eclipse under construction
91 AWD turbo talon under construction
98 extendedcab s-10 under construction
S W A T!
141.3 dash (97 sunfire)
140.3 kick (97 sunfire)
  • Who's Online   0 Members, 0 Anonymous, 3236 Guests (See full list)
