How Should I Wire?
How can I wire my 4+4 ohm subs? I have to of them and the ohm load is 4+4, I know someone previously told me but I am not sure. I want to go as low as possible
2 MAW15's
Cadence 1000D
Infinity Reference 6022's
Blankput Tweeters and Infinity 4x6's with tweeters
Powered by a US Acoustic USB4085
1 Rockford 1Farad Caps and a 200 amp ALT
You need to be more specific. Are you saying each speaker is dual 4 ohm? Or single 4 ohm? If im reading it like i think youre saying which is single 4 ohm the lowest you can go is 2 ohm. Wire them in paralell.
Brett
(I just read the speakers in your sig. If those are the ones then wire each speaker paralell to give each a 2 ohm load then as long as the amp is 1 ohm stable then wire each speaker paralell to the amp giving you a 1 ohm load. Basically the lowest you can go for daily.)
ok, yes each speaker is 4+4
So it is AMP + to both speaker +'s on each sub.
2 MAW15's
Cadence 1000D
On each speaker, wire + on one voice coil to + on the next and then do the same with -. Then you want to wire from the amp +, to each speaker, 2 wires comming from the amp +. And do the same with the amp - to the - on the speakers.
Brett
Like that correct?
2 MAW15's
Cadence 1000D
thats with 2+2 subs I couldnt find 4+4 ohm subs I am just looking for the wiring to be used
EDIT
The wiring is the same for both sites just one is 2+2 subs the other is 4+4 subs
2 MAW15's
Cadence 1000D
Yep each will gett 500RMS because the cadence is 1000RMS :D thanks alot to everyone
2 MAW15's
Cadence 1000D
  • Who's Online   0 Members, 0 Anonymous, 981 Guests (See full list)
