Posted (edited)
http://www.sonicelectronix.com/item_6189_P...ik+A1800DB.html
Unfortunately most of the Power Acoustik amps are sold out in this site
You will need 900-1200 rms at either 4 or 1 ohms [look for amps with these specs]
Planet audio is good too
But as most would recommend, go one more check without subs and save for a more expensive amp. But if you can't live without beat, this will surely work for you
Edited by hotshot27
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
what abut crunch?
depends which model, its really hit and miss
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
Power acoustik may be overrated, but even if its 20% inflated ratings it is still hard to beat for the price. I have had success with the gothic series in particular.
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
