95_1500 Posted October 9, 2009 Author Report Posted October 9, 2009 Todays progress: Still gotta machine a spacer/sleeve allinone for the bearings on the lathe tomorrow, solder some more 1/0, connect the plugs to an ignition, paint the bracket, find a proper length belt... Tacked My boy Bill weldin it up for me Bolt on dual alternators in 5 "easy" steps Step 1 2 3 4 5 Original Build http://www.stevemeadedesigns.com/board/index.php?showtopic=24095
95_1500 Posted October 9, 2009 Author Report Posted October 9, 2009 Sorry all I have on me is my phone but still 3.2 Megapixel pics is betta than none Original Build http://www.stevemeadedesigns.com/board/index.php?showtopic=24095
95_1500 Posted October 9, 2009 Author Report Posted October 9, 2009 Went ahead and wired up the plugs, simple one wire to an ignition that tells the alts to turn on.. Found my wire. Tapped into the "ignition A" in the fuse box under the hood Soldered Will re-run it later but for now its zip tied up away from the exhaust.. One less thing to do tomorrow! Original Build http://www.stevemeadedesigns.com/board/index.php?showtopic=24095
huesos Posted October 9, 2009 Report Posted October 9, 2009 Those dual alts are straight sexy bro nice work on em. "FRIENDS MAY COME AND GO BUT 200 POUNDS WILL ALWAYS BE 200 POUNDS." -System in progress- SYSTEM SHOULD BE DONE BY THIS MONDAY!!!!!! 15.2 Orion HCCA 4 Cubic ft tuned to low 30's MB Quart DSC1500.1D Kinetik HC1800 Kinetik HC800 50ft of KnuKonceptz 1/0 gauge 10ft Kicker 4 gauge "LET THE PAIN COME OVER YOU, BUT NEVER LET THE PAIN OVERCOME YOU."
95_1500 Posted October 9, 2009 Author Report Posted October 9, 2009 Those dual alts are straight sexy bro nice work on em. Thanks man.. Cant wait to get em runnin Original Build http://www.stevemeadedesigns.com/board/index.php?showtopic=24095
95_1500 Posted October 9, 2009 Author Report Posted October 9, 2009 Jeeze tough crowd Been here for about an hour, going to actually start work (real job) here in a few minutes then head to the machine shop about 10 or so to make the bearing piece. Original Build http://www.stevemeadedesigns.com/board/index.php?showtopic=24095
Marlo Stanfield Posted October 9, 2009 Report Posted October 9, 2009 Very nice finished product on the bracket, high quality welds too from what I can see. Hairtrick vids were pretty good too, things just get louder from here though. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
95_1500 Posted October 9, 2009 Author Report Posted October 9, 2009 Very nice finished product on the bracket, high quality welds too from what I can see. Hairtrick vids were pretty good too, things just get louder from here though. Thanks bro! Just finished machining the bearing piece. Gonna spray the bracket black, solder my other ground 1/0, put it together then measure for my new belt. If it goes as planned should be runnin tonight. Original Build http://www.stevemeadedesigns.com/board/index.php?showtopic=24095
95_1500 Posted October 10, 2009 Author Report Posted October 10, 2009 Idk why but decided to spray the bracket chrome just cuz i had the paint layin around This is the bearing piece, it is 3/4" diameter for 1/2" of the length as the spacer. The bearing holes are 17mm (.669") so i milled the part they are slide onto just .5 thousandths over (.6695") so it was tight, then pressed them on. The whole piece has a 1 thousandth under 1/2" hole drilled through it and the bolt itself is 5 thousandths under 1/2" so theres only 4 thousandths of an inch of play between the sleeve and the bolt. Snug as a bug in a mothafuckin rug! The bearing bolt is a grade 5, 1/2"-20. The two 1/4" steel plates are tapped, the bolt is threaded in tight and then a nylock nut is tightened onto the backside. Both grounds Two alt grounds (yes one is red, i had plenty of red left over from installing the D3100 but no black) and my driver side battery ground, the passenger side battery is grounded in the same spot on the other side framerail. So literally EVERYTHING is done except a belt.. The closest thing i could find at Advance auto at 8pm was an 111.5" and i need about a 110.25". Sooo freaking closeee Original Build http://www.stevemeadedesigns.com/board/index.php?showtopic=24095
98crewcab Posted October 10, 2009 Report Posted October 10, 2009 good god bro....nice work. If I was close enough, id shake your hand....and say whats up to your sis I kid I kid!!! where did you find the bearings? is that a napa part? 06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck) 7" BDS HC lift kit (5) 37x13.5R18 Toyo Open Country M/Ts (5) 18x10 Moto Metal MO962 tablet in lieu of deck blue tooth interconnect to soundstream eq (for volume control and bass control) 4 Alpine type r 10's 6 cubes net, 80sqin's port, tuned to 33hz 2 brutus brx5000.5's 2 pairs 3" polk audio for a pillars 4 pairs polk audio 6.5 comps 1 pair 8" polk audio for mids 2 xspower d3400 batteries.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!P.S. Thanks Steve....for the demo!!!! loud as fauk!
