also another thing good about brad nails is some (or most) actually have glue on them that melts when u nail the wood. so once the nail is in its glued in and can hold the wood firmly just like a screw but its much faster.
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Ill take screws over brad nails ANY given day. Screws actually pull the wood together and leave no seals but the brad nailer just holds the wood in place. That is why when you get to building box's for bigger set-ups people dont use brad nails.
I use both. Since I dont have access to a table saw I have to build all my boxes with a circular saw, so if I have any imperfect cuts I use the screws to pull the wood together better. Brad nails do pull the wood together, but not nearly as tight as screws. If you are using a table saw, and make perfect cuts everytime then a brad nail, and glue is all you need, like Meade said.
My System:
Pioneer AVH-P3200BT
4-Dayton 7 inch reference series (front doors)
8-Onkyo 3/4 inch tweeters (dash)
1-Sundown Audio 100.4D (mids/highs)
2-18" BTL's (for now)
Crescendo 3kwp (for sale)
Complete rebuild coming soon...
im in your boat far as circular saw..and i dont like bugging the homedepot guy cause they always seem like there in a rush..
http://www.cardomain.com/ride/3042878
TEAM DEADLY HERTZ
"GET LOUD OR DIE TRYIN"only the loudest will survive.
i got my circular saw for $25 last year and it works like a champ along with my brand new $10 jigsaw ........... all from the pawn shop. man i tell you, you'll find some good tools brand new or hardly used there.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
