You should go on google and search for audio shops in your area chances are you could find one that would build you a box. I dont know where you are located but you may have to go for a little drive. We have all had to do a little research. Good Luck
1 15" Nighthade
Sundown 1500D
3.4cubes @ 34
I already researched, closest shop is a 3 and a half hour drive
1997 4 Runner
Alpine CDA-9886
4 Fi Audio X Series 12's
1 Crunch GP3000D Pro
DC Power Inc. Alternator(Kickin out 15+ volts!)
are the dimensions in the first post, your inner trunk? or the opening? it would suck to build a box with those specs and not get it to fit.
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
its for a 4 runner so the width is from fenderwell to fenderwell and the depth is from back door to top of seats, and the height is from floor to top of seats, im sure it would fit
1997 4 Runner
Alpine CDA-9886
Posted (edited)
are you gonna have access to fiberglass or all thread? i'll se what i can do, it'll prolly be til tomorrow though. i'll try and make it subs and port back, tuned to 32 hz using kickers specs for large ported box. let me know if you want different tuning soon.
Do you have google sketchup?
if not, try and download it [its free] and i will send you a file of the box when i get it done
Edited by hotshot27
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
box plans are done, i did a dual chamber box, about 4 cubes per side, subs up, ports back, tuned 30-33hz.
PM me your email and i will email you the file.
And if you want some minor changes let me know and i can see what i can do.
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
((((((((((((((((((((((((((((((((((((((((((((((((((((in stereo)))))))))))))))))))))))))))))))))))))))))))))))))))
team audio thugz uuUhhHhhHhh. straight ghanxstuh since 2007.
Here is a quick idea of what i think would work for your 4 runner.
hope everything works out.
