I have a 2 farad cap and the ONLY reason I use it is because it has a voltage display on it. And it was free. Multiple batteries would be a good idea if you are running 5500 watts. and a new alternator
ok how many batts and how do you wire them up?
i would do 2 Optima YellowTops if your on a budget but if you have the money, go with 2 Deka Intimidator 9a31's.
I think you wire them up like + from batt 1 to - on batt 2, someone fix this if its wrong
0 ga would be best
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
I think you wire them up like + from batt 1 to - on batt 2, someone fix this if its wrong <----- :excl:
:blink:
+ to + and - to -
Team Ampere Audio
so if i go pos to pos and neg to neg its not going to hurt my cars comp or alt any thing elec?
Should be fine, Run a power wire 0 guage from your front battery to your back battery, and find a good ground on the frame for the battery in the back.
Team Ampere Audio
all the batts do is store power to be used, like a cap, but in much greater quantities. batts should be wired in parallel, and a HO alternator is almost a must for a 5500 watt system to not have serios voltage drops
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
rock on ill try that but i dont have enough cash for a bigger alt so ill just have to wait but ill try the 2 batts for now untill i get enough cash for a better alt thx for the advice ,so does any one want to buy a cap lol j/k
  • Who's Online   0 Members, 0 Anonymous, 1403 Guests (See full list)
