50 gazillion. then sell it and buy one or two deep cycle batteries
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
scratch the cap idea ....look into 2 good batterys...>powermaster,kinetik,DC
X2
Tried caps before with under 2k watts, will go with more batteries every time from now on.
caps hardly solve the problem with dimming lights, all's they do is put a bigger strain on your electrical system and cause it to fail faster
Batteries>Caps no matter what someone says about caps
Edited by Krannyman92
I have a 2 farad cap and the ONLY reason I use it is because it has a voltage display on it. And it was free. Multiple batteries would be a good idea if you are running 5500 watts. and a new alternator
Edited by hotshot27
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
Sell the cap, and buy a stinger volt meter with it. Problem solved.
Take the money you were originally going to buy for caps, and put it for like 1 nice deep cycle battery. Its like having a million caps. Go with a Kinetik HC 2400 or a Power Master D3100. Hell even another Optima would be 100x's better than a cap.
I have heard of people having a cap on their system, then take it off and gain 3dbs from doing so. And like it was posted before, read the quote in my sig.
the hc600 is 100 1F caps or something right...so the hc2800 is technically like 500F :), the Deka 9a31 is around 500 Farads too
  • Who's Online   1 Member, 0 Anonymous, 707 Guests (See full list)
