ptcary Posted June 30, 2008 Report Posted June 30, 2008 I have a Soundstream 7-band parametric EQ that will be used to tune my new setup. I have a general understanding of parametric EQs, but how do I set the "Q" for each band? That is the "width" of the tuning frequency right? Is narrow width better than wide? Also what is a good frequency to set the subsonic filter at? 20hz? Here are specs, if helpful... Soundstream PQ-7 Parametric EQ w/ crossover Inputs/Outputs: front/rear/subwoofer Variable front EQ frequencies: (30~350Hz), (100~1K Hz), (330~3.3K Hz), (1.5K~15K Hz) Variable rear EQ frequencies: (200~2K Hz), (1.5K~15K Hz) Variable subwoofer EQ frequency: 20~180 Hz Q-Factor control for each band: 0.5~20 Gain control for each band: +/-10dB Subwoofer Channel: 24dB crossover slope Phase Control: 0~1800 Variable Sub Sonic Filter: 10~80Hz w/Q-factor (0.5~1.2) Max Input Level: 10V Max Output Level: 10V Frequency Resp: 10Hz-50KHz THD: 0.01% S/N ratio: >110dB Input Imp: 10K ohm Output Imp: 150 ohm PTCary 2003 SMD PT Cruiser 2011 Honda CBR 250R 2010 Mazda 3i Sport MY BUILD LOG
swervinmylac Posted July 10, 2008 Report Posted July 10, 2008 I have a Soundstream 7-band parametric EQ that will be used to tune my new setup. I have a general understanding of parametric EQs, but how do I set the "Q" for each band? That is the "width" of the tuning frequency right? Is narrow width better than wide? Also what is a good frequency to set the subsonic filter at? 20hz? Here are specs, if helpful... Soundstream PQ-7 Parametric EQ w/ crossover Inputs/Outputs: front/rear/subwoofer Variable front EQ frequencies: (30~350Hz), (100~1K Hz), (330~3.3K Hz), (1.5K~15K Hz) Variable rear EQ frequencies: (200~2K Hz), (1.5K~15K Hz) Variable subwoofer EQ frequency: 20~180 Hz Q-Factor control for each band: 0.5~20 Gain control for each band: +/-10dB Subwoofer Channel: 24dB crossover slope Phase Control: 0~1800 Variable Sub Sonic Filter: 10~80Hz w/Q-factor (0.5~1.2) Max Input Level: 10V Max Output Level: 10V Frequency Resp: 10Hz-50KHz THD: 0.01% S/N ratio: >110dB Input Imp: 10K ohm Output Imp: 150 ohm did you ever get the pq7 up and running... cuz im looking for a eq/crossover and i was thinking about that one to
ptcary Posted July 13, 2008 Author Report Posted July 13, 2008 Not yet, I gotta find a place to put it where I can get to it for adjusting, but under my amp rack. When I get it up and running, I'll post how it works out. PTCary 2003 SMD PT Cruiser 2011 Honda CBR 250R 2010 Mazda 3i Sport MY BUILD LOG
