My Update On My Groundpounder
you can port 4 12s you CANNOT port 4 15s and have them perform like they are supposed to in that trunk...
Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
i kinda figured that...i probably settle for four sealed 15's if i can find some
4 hdc 15s ported in that trunk wouldnt work. 4 12s would prolly be a tight squeeze. just my $ .02
99 durango slt:
88" chrome, cleared out up front. altezza rears.
system:
2 Fi SSD 18s
Bxi2607D
12cuft tuned to 35hz
how big is your trunk? hte min. airspace for FI Q 15's are 2.8cuft a piece...im think you will need about 12.5cu ft GROSS for 4 15 Q's ported..
also its prolly easier to get 4 hdc3 12's in there..big you still going to need about 8cu ft NET...
http://www.cardomain.com/ride/3042878
TEAM DEADLY HERTZ
"GET LOUD OR DIE TRYIN"only the loudest will survive.
you'd have a hell of a time fittin 4 hdc315's let alone powering them. and even at that the box would be almost sealing it self causing it to not be as loud
oh ok i understand that part. i think im just going to go with four high quality sealed 15's. im looking at the cone area advantage with a ground pounder setup i dont know why but i keep goin back to the cvx's is there any others out there for a good sealed sub.?
your trunk will be loud :)
well i just asked the guy odd realmofexcursion and he said it has 13 1/5 cubes to work with
well do the FI 15" Q's then on 4kw-6kw and that shit will pound..... http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif
you MIGHT get get away with 3 HDC3 15's.. FYI HDC3's require alittle more airspace then other subs...but 3 15's on 6kw will still be loud...
TEAM DEADLY HERTZ
