**big Update**(6) 15" Jbl Gti's In An S10 Blazer
do i see 10+ runs of positive and negative each?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
well yes and no...
it looks bigger than it is :
3 pos to main (fused) -"as for the batteries(pos and neg) in the back i got some distribution blocks under the box"
3 neg to main /
9 to individual amps pos (fused)
9 to individual amps neg
so techn its 6 runs of 0g.
but i got all 0g. to evry amp in there
*2013 NEW BUILD*
12- 18" Crossfire XS v2's B pillar 4th order wall
4- Crossfire 8K mono blocks
40+ pro audio mids tweeters and horns
3- Singer alternator 400a external regulated alts
tons of audiotechnix wire
24- XS Power D1400's
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
All I have to say is god damn. that blazer is goin to be knockin. let me know how you like those jbl 14001.
[/quote
:diablo:
ok i rly am not having good luck with them....:censored:
:help:
ok if i can explain this i will .....
i sent off 2 of my other amps to a jbl rep they are supposed to fix them, them play rly clean at low low volume but if i crank them its almost as if they shut all power off and slowly fade back in??????
vry angry
no protect lights???
no pop
nothing they act as if i just turned them on???? but they only do this when they rly start beating.....?
please if some one is reading this and has advice help me out b/c the jbl peeps said they will not have time to fix my other 4 amps??????
i havent even received the amps back frm them but they sadi i should this week....
rly should i just go with diff amps????? "POST YOUR OPINONS!"
if you think i should then throw out what you think i should consider... try and keep it reasonable... but yet powerfull...lol i know to hard things to mix
but i am in a bad sittuation here :help:
help me out mane my head is hurting from thinkin abt this shit !!!!!!!!!
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
That shit looks sick
thanks man
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
Check your voltage at the buss bar. A crazy voltage drop will shut off your amp .
nvr drops under 12......
and i unhooked evry amp but 1 and the dam thing still does it ????
its as if the amp goes to protect mode but it doesnt???
it acts just like you said the volt drop... the reason i say this is b/c the amp has illuminated accents... and they shut all the way off and the power led goes out but is quick to come back on????
what els do i need to do...
and tell me anything that i could possible upgrade if i havent already
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
