What do I need to run it? I have a kinetic power cell, should I use that and maybe run 0 gauge wire and a yellow top?
Yes go with the Kinetik.
It would be nice to know witch Kinetic it is though and I will have to research it before I can give you any info about if its rite for you.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
You can get away with the 4 gauge wire after all other work is done. I still don't recommend it though.
Do the Big 3 out of 1/0 guage first and it may solve your problem and save you from buying a new 20 foot piece of wire.
If I do the big three will that void my warranty. I paid a shit load of money for the 100,000 mile bumper to bumper warranty
I can't answer that.
if done propperly
I don't see why, everything should be able to be taken out like there was never anything done except for the hole you may have to make for the ground wire.
You may want to have a profesional do it if there are concerns.
If you like you can try useing a 150 amp ANL fuse instead of the circuit breaker.
It may have a better tollerence but it will probbly blow at some point.
I wish someone else would jump in incase I'm taking you in the wrong direction but I believe its a lack of current flow issue.
^^^^^^^^^speaks teh truth
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
yuppp teh lack of current FTL
~Matthew
your drawing to muich current and its flipping the circuit breaker because you are drawing more then the 100 amps the circuit breaker is set for.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Alright guys I got it fixed, I really appericiate all your help. I ended up running a 150 amp circuit breaker and hooking up my kinetic power cell and it doesnt blow the breaker. I dont know what I would do without all your help, once again thanks so much.
