which way is better for wiring two amps
with distribution blocks or runnin to sets of power / ground wire?
-thanx
DC Sound Lab & Rockford Fosgate FTMFW
you could turn it into quarters and put it in a pool. no one suspects a person of doin drugs with a pool full of quarters
Between his box and gangsta lean, You gotta be a legless midget to sit back there
It depends on how big the amps are.
I like distribution systems and no matter how big the amps seem to get they bring out bigger wire to acomodate the install.
2 1500 watt amps, they now make 3/0 LOL one run of 3/0 to a distibution block and split it off to the 2 amps.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
well im running two kinda small amps
T5001bd and a 201s
T5001bd and a 201s
If it was me doing what you are doing I would distro blocks without question.
You just need to sit down and figure out how much current you might need to pic out the size of your main feeder wire.
  • Who's Online   0 Members, 0 Anonymous, 395 Guests (See full list)
