I just finished building my wall for 4 15" DC lvl 3's and it doesn't hit. Im pretty sure my calculations are right but if someone can check em that would be great.
Inside box dimensions:
L- 43.25"
H- 32.21875"
D- 18.75"
Total= 15.12 cu. ft.
Sub displacement= 0.88 cu. ft.
Brace and 45's displacement= 1.2536cu. ft.
Port displacement= 0.375 cu. ft.
12.6114 cu. ft. net
3.15 cu. ft. per sub
Port size= 12"x12"x5"
I am running the subs off of 2 Cerwin Vega 1200D (2subs to 1 amp) wired to 1 ohm.
Any help would be greatly appreciated.
-Thanks
im only getting 12.8 cu ft before displacement.
he said they are inside dimensions not outside :)
DC.jpgDC POWER
Ive checked my wiring like 5 times and ive even rewired them with 12 awg wire so that the whole wire would fit into the terminal...and when there playing they all look like their moving the same
