So, ive got two 15" DC lvl 4s with lvl 5 voice coils. They are Dual 1s. Im using a Hifonics Bxi2607d which is 1 ohm stable.
How do i wire the subs to 1ohm?? Ive been looking for a simple diagram.. Would anyone mind explaining it to me? Or maybe even drawing something up?
Sorry :'(
2008 Hummer H3
x2 Sundown Audio Nightshade V2 12s
x1 Sundown Audio 3000D
Connect positive to positive, then to positive on amp.
Connect negative to negative, then to negative on amp.
Best bet would be to check out the12volt.com for your answer. They have a Subwoofer wiring diagram on there that comes in handy.
EG Limo
Chrysler 300's Stretched
Lambo Doors
20" Rims
You realize he has Dual 1s right? thats .5 per sub and when hooked up to the amp itll see lower than that... wire them both in a series and hook one sub up per channel
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
Guest aseanj52
Or.....if it is mono.....like just 1 positive 1 negative......
You can run each sub in parallel.....then at the amp.....switch the positive and negative. so....
SUB 1~~~ positive to positive/negative to negative
SUB 2~~~ positive to positive/negative to negative
at amp~~ positive with negative on both.
i think........maybe...... :ph34r: ..... if i'm lucky..... :clover:
Edited by aseanj52
might be wrong too... i need sleep lol.
Need any thing chromed? Hit me up!!!
gamer tag: (360)
mEmEnToMoRi64
My Myspace
refs:
from here: RollinSoLow, Derrick824, Ray
from c.a.c.o. : teamsubgopoof, splvictim20, SundownAudioNY
from C.A.J. : Donpisto, spladdict19, CAJunkyard, JBLCAMRY, DasBot (robot underground)
from ca.com: alxmlr789,photocrazy8
Guest aseanj52
That's basically what i was saying except take the yellow and blue wire and go to the amp.........but i think that would work.
lol, or
man i need sleep lol
gamer tag: (360)
mEmEnToMoRi64
My Myspace
refs:
Guest aseanj52
Someone finally got a good link up....instead of 2 tired guys trying to explain and draw something....lol
Edited by aseanj52
  • Who's Online   1 Member, 0 Anonymous, 1600 Guests (See full list)
