I hope this works for him, cause if it does ima get the same setup, except ima run ported
1997 4 Runner
Alpine CDA-9886
4 Fi Audio X Series 12's
1 Crunch GP3000D Pro
DC Power Inc. Alternator(Kickin out 15+ volts!)
that's part of the reason i brought up the ebay box thing. it COULD sound good, but then again it COULD sound bad. then you both would be sad when the equipment has potential like it does. but...that's when testing comes into play
And also when im setting the gain on my amp n the RMS guide should i go by the max power rated at X amount of ohms or what
you have to go by the RMS power of the amp, max power means absolutely nothing.
just basically go to w/e ohm load your going to hook it up to. if your shooting for 1 ohm, do around 1000rms on the graph, if its 4 ohms do around 800-900.
gotcha, but yah if they sound decent in my seperate ported boxes, then i will build a single ported box for all 4, and as for him idk its whatever he wants to do its his money his system
1997 4 Runner
Alpine CDA-9886
