the amps are jbl 1400.1
i hate them so far?
they play and sound good but when you crank the deck and get the sub actually pounding they shut off(almost as if they loose their power, and they slowly fade back in... but only to cut back out after abt 20 sec..?)
any ideas
i have sent off 2 of my amps to jbl they say they have them fixxed ... but they also said my new 4 that i just ordered will not do this??? but yes they do......
and to top it off they said they dnt have the time to mess with my amps for now.....
no protection lights....
no popping
not a single thing....
they act as if i cut the power off and plug them back in????
they punch rly hard then cut out then fade back in and cut agn.....
PLEASE HELP IF YOU CAN!!!!!!!!!!
*2013 NEW BUILD*
12- 18" Crossfire XS v2's B pillar 4th order wall
4- Crossfire 8K mono blocks
40+ pro audio mids tweeters and horns
3- Singer alternator 400a external regulated alts
tons of audiotechnix wire
24- XS Power D1400's
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
loose grounds?
rcas maybe?
try on a friend car and see if they do the same thing if they dont that means its your wiring if they do that means the amp is fucked..
Im a scamming little cunt rag. i like penis, cum more penis, oh and did i mention penis.
i suck at life....
... yes they get ...kinda of hot but not out of the ordinary.....
i had the older jbls and they got way hotter, and i just bought new tsunami rca's, and i had 2 of these and jus ordered 4 more and they all do it ? i had ordered my friend 1 and it does it .....
i dnt know what to do if i put other amps in they r fine but
what can i do?
theres no way all those amps can have the same thing wrng and no one else complain???
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
http://www.stevemeadedesigns.com/board/ind...showtopic=24659
that is my build thread if ne one wants to look it over and tel me what they think.....
and yes i was vry upset that they couldnt even tell me where or who else could possible help me ....
and to be honest i dnt kno if i want them warrenty....
i may just have to face it and buy sumthing else?
but i now have 6 of these????
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
sound like shitty customer service to tell you they dont have time to warrenty your amps.are you runnig them at rated impedence loads
yes i am im actually not runing them hard at all im running them at 3 ohm??
i am clueless???
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
Are you running them under their recommended impeadance?
Sounds like a voltage problem.
I ran my GTO601.1 at 1ohm (recommended 2ohm) at 14.4v never once had an issue with it or it getting hot. I know its not the same amp but JBL makes a pretty bullet proof amplifier for its price range.
How many subs are you running off one of those?
im running at 3 ohms i have 1- 15"gti on each i have 6 amps and 6 15's..
my volt doesnt drop under 12 but do you thnk that is to low????
and as i said they dont get rly hot just warm... i have always been vry pleased with jbl untill this product i bought 2 of these abt 2 months ago and these 4 now and they all do the same thing????
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
  • Who's Online   0 Members, 0 Anonymous, 903 Guests (See full list)
