Guest aseanj52
I'm not sure I haven't payed that much attention. And the ground in 8 gauge, 4 gauge power
:01nocomment8so: Power and ground should be same size. Who installed it?
power and grounds have to be the same size!!!
do that first and check back with us.
That would be me, it's what I had laying around :unsure: I guess I'll go pick up some 8 gauge power wire in the morning and let you guys know
2000 Jeep Cherokee
-DC Audio
-Memphis
-Audioque
-SecondSkin
-Pioneer
-KnuKonceptz
Guest aseanj52
O.o wrong answer.......get 4 awg ground, clearly the amp needs more ground. You want your shit to blow. =@
I see
2000 Jeep Cherokee
-DC Audio
-Memphis
-Audioque
-SecondSkin
-Pioneer
-KnuKonceptz
wow im glad someone caught that. i was gonna jump on that
up your wire, make sure you got a god clean solid ground (no paint, rust, just bare metal) make sure your RCAs are in nice and tight.
if you still get a noise get a GLI (ground loop isolator) they work 50/50 sometimes they cut it out completely, sometimes they make NO Change.
NoFearX18 said:
trainman0978 said:
Yup just get a short piece of 4 G to ground it. Prolly cheaper than runing all new 8 G, and better than 8 G. And like Chode said the GLI work about half the time. But Im betting its the ground wire. Change that out and sand down you ground connections. Lets us know if it worked.
isnt that called engine noise?.lol.i had that before when i had my sony deck..but once a removed that deck and went with kenwood the noise just disapeared outa no were..and also when my battery died i had it removed and bout a new one the noise came back..but it was because my ground from the engine was loose..idk y...its weird thoug.
