Amp On/off Switch Meade Uses?
Im talking about the thing that he allways holds and then cranks the bass. Does anyone know what that is called? and where to get a cheap one?
Im putting 4 kicker 15" cvr's in a walled box where my original rear seats were. With a zx1500.1 amp. And i just want the bass a little bit loud to trick people into thinking my system sucks and then I just want to slam that switch and make it knock hard.
I was thinking about putting a 12v on/off switch on the remote amp wire but that would just make the subs go off and then on. And i know your not supposto just hammer the bass full volume from off to on quickly.
Nah im not talking about the bass knob. Those bairly make any difference from loud to quiet. Its like a controller thing he has with like 5 buttons on it.
what the hell are you talking about?
Need any thing chromed? Hit me up!!!
gamer tag: (360)
mEmEnToMoRi64
My Myspace
refs:
from here: RollinSoLow, Derrick824, Ray
from c.a.c.o. : teamsubgopoof, splvictim20, SundownAudioNY
from C.A.J. : Donpisto, spladdict19, CAJunkyard, JBLCAMRY, DasBot (robot underground)
from ca.com: alxmlr789,photocrazy8
what the hell are you talking bout?
See I knew I wasnt a moron. I would have got a bunch of shit talkers for this post if I didnt find what I was talking about. It plugs into your RCA cables to adjust signal voltage. It is not a booster of any kind. It cuts out your signal voltage through your rca's and you can turn the dial as little as you want untill you get more voltage and your at normal flow.
x2
He uses the RF bass knob. They make a big difference when set up correctly. Remember to tune in you amplifier settings with the remote knob all the way up.
x3
its a bass knob.
i know when i turn mine down...the bass is mostly gone with how i have the amp set up when i crank it ITS CRANKED!!!
NoFearX18 said:
trainman0978 said:
Yup its all how you set up your amp if you do it correctly then the knob should make a big difference and yes they do have rca ones but if your amp has one you shouldnt need one of those.
I think when I set my amp setting mine my knob either half or 3/4 of the way up. And like chode said if my knob is down then there is almost no bass.
  • Who's Online   0 Members, 0 Anonymous, 2152 Guests (See full list)
