4 Re Xxx 12" Vs 4 Memphis Mojo 15"
JAY-P
Mojo isnt a SPL sub per say, the Quad coil Mojo is, its got the coil designed for SPL, and the extra packed on spiders for a higher FS
The standard Mojo DVC 2ohm or now I think also DVC4ohm have less spiders, a lower Fs all the way around
Ive ran many Mojos, and installed many, I seen them things put out some serious lows, and fast transient response
Now the XXX newer series, I dont have much experience with, but i do remember them things suposed to be rated highly in the SQ area
but SPL, overall DBs, the Mojos hands down
excursion isnt as important as u think
if you play a 20hz tone.... id bet ud beat almost anyone in excursion.... o yeah and ~2500w to do it lol
18s personally sound great and are not lacking in upper bass nor are they inaccurate... put that in the car audio myth file
18's are the most efficient.... and if you have the choice and money isnt an issue... duh 15's
Thanks alot for your help. My install guy here in NY doesn't know about RE audio. He's a JL audio guy and he wanted me to go with 4 JL 10w7's, 4 EV 10's for mids, 4 6's and 6 beyma bullets. I think that I'll either go with 4 XXX 15's or 18's! I still don't see how people think that the Mojos would hang with the XXX series when the Mojos are 1000 watts rms and the XXX are 2000 watts rms!
wattage along with excursion doesnt always count
also that 1000rms is way underrated, there are people running 4000rms on them mojos. I knew of a guy running the Mojo MAX 15s just 2 of them, and had 4- 4kws per subwoofer, thats what, 32krms?
It was hitting mid 60s, walled off, tons of batts, and they were the Mojo Max, but again they were rated only 4krms 8kmax and this guy ran them for about a year before changing the system out
If you ever take a good look at a Mjos coil, and compare it to just about any other coil, you will be suprised. They rate it at 1000rms, ONLY due to warranty, but even 4kw on daily is possible
Ok, i understand. How much rms would I be able to hit XXX with then. They say 2000watts rms 4000watts max.
dunno, thats Rays dept ;-)
hes watching
Iam just sticking up for Memphis cuz I used to work for them
and I know what they are able to do
Lets just say that Memphis under rates its shit..alot..I am lucky,the shop I work for carries Memphis and up until not long ago had RE/Us amps..so I got to play with both
I think he was looking at the xxx 12's and mojo 15's.....the xxx 15's are bad mofo's for sure though!!
things changed
15" LMS Ultra
AB VFL 200.1 3kw+ rms@ 1 ohm <-- 500.1 in near furture
3.5 cubes at 34 hertz
2 Exide Orbital's
200 Amp EA Alt
125 sq ft BXT
things changed
Yes they did! Thanx for all of you guys input! I think 4 XXX 15's or XXX 18's! It will definately be one or the other!! I just hope that onlinecarstereo.com still carries the autotek MM 4000.1D!
  • Who's Online   0 Members, 0 Anonymous, 2193 Guests (See full list)
