skynoverya550 Posted July 28, 2008 Report Posted July 28, 2008 I just installed my new HU. its a eclipse DD everything was fine for a couple days.. turned my key on sunday morn and head a wierd noise through my door speakers. kind of like a buzzing noise. turned the truck on and still heard it. while driving the speakers kind of clip in and out as well. especially the two bose( factory ) tweets in the pillars. AND! you can hear engine whine through the speakers. the stereo is completely factory besides the HU. the truck is a 08' 2500 hd and it has the bose stereo. you think the Plug went bad?
Bass4Lyfe Posted July 28, 2008 Report Posted July 28, 2008 Okay what it might be is your ground. Pull that HU out and check the black sort of thicker of the bunch ground wire, it should be almost the same size as the red +12 constant and +12 switched .... make sure everything is soldered and tight, if it is come back and tell us but my guess is a wire came a little loose. if that don't fix it try a GLI (ground loop isolator) Hope i gave the right advice here ~Matthew 1998 Toyota Camry XLE V6 3L (1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm with Shock and Proximity (1) 20% Tint All Around (Gately Audio) (1) 250 Amperage HO Alternator (1) Big 3 Done In 1/0 (2) Kinetik HC2400 Power Cell (1) Alpine IVA-D106 Receiver (1) Peripheral Video Bypass Device (4) Alpine SPS-17C2 Speakers (1) Alpine KCE-422i iPod Control Interface (4) Sheets Dynamat Extreme; for speakers (1) 10 Square Feet Hushmat (Trunk & Rear Deck) (4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils (1) Wall Built By David, Tuned to 32 Hz (1) Rockford Fosgate T40001bd Amplifier (1) Stinger 1/0 Wiring (2 runs of + 2 runs of -) (1) Stinger Volt Meter
roscoe1129 Posted July 28, 2008 Report Posted July 28, 2008 bad ground or your pac interface is bad. Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
