Batts...
Ok, I had alot of financial setbacks in the past month so I have lil dollars to my name. My question is.... Will my Honda Civic (daily driver) be ok running 1100 watts on the stock alt. if I upgrade the battery to a good one like a Kinetik hc1400? If so, will I be able to add a small 4 channel amp later if I want to? I cant afford to upgrade both and wont be able to save for it for a while due to insurance payments coming up. I just bought me a 15" S.I. Mag and I'm powering it with a Memphis MC1000d (2 x 40 amp fuses)  and I like to listen to my music at 3/4 volume so it's loud and low... Will I be good to go?
New project in the works ;)
I'm guessing your stock alt is around 70 AMPs hot. I would say that with a good battery or 2, you might be able to get by just fine...(might) I would invest in a H/O alt. but I understand you're low on cash so do the battery.
Guest MegaloManiac
mags are cool :) where did you buy it, pics? post a new thread about..thanks
I have a 2000 accord and my stock alty had a  65a hot. My lights dimmed like a mofo off just 1200 watts(i didnt have a front stage at the time), had a yellow top under hood
a 2nd battery should help, but an HO alty should help a lot more.
Thanks man, the mag is supposed to come in sometime this week... There was a mix up though with the measurements of my trunk and I've built 2 boxes for it now and neither will fit... go figure. So now I'm trying to contact Nick from SI when it gets here to see if I can switch it out for the 12". If thats going to be a problem I'll just sell it, prob. for a little less then I paid. I purchased it from Kevin at Low Hz. You think 1 optima red top under the hood and a yellow in the trunk will be suffice for the 1100 watts? I really wont be able to afford the Alt. for a while due to being 17 and having to save for my insurance, it's not easy lol. If I could I want to pull off a budget Steve Meade haha, I wish.
Guest MegaloManiac
i think it should be fine, try it with 1 battery and see then ifit still does it then get add the battery
haha.. you wont be able to do 1100 watts off your 75 amp MAX alt. believe me i tried. i have a civic as well i bought a 135 amp alternator and a yellowtop and kinetik hc800 and its finally ok...
18's in a wall to come....Its not all about the posts....check the member #...
  • Who's Online   0 Members, 0 Anonymous, 4546 Guests (See full list)
