Box Help Non Noob Question
ok so i cut my wood for my box and figured out i messed up on some of the measurements. the box is alot smaller than i expected and is not utilizing alot of space in my trunk. now i want honest anwers and i know bigger=louder.
im wondering if it will be worth making a new box that will be a little bigger
the current measurements on the box i have now is this
15x32x12
and this is the max measurements i have to work with
20x40x15
is it worth making a new box with the bigger measurements?
will it be any louder?
by the way its slot ported to 39 htz and its for a hdc312
thanks in advance
What kind of power you putting to the woofer?
Rollerz Only - Sacramento Chapter. 6 Time Lowrider Magazine club of the year
94 Xploder on 22s - Gutted for now...
87 Cadillac Fleetwood Brougham on hydros, fully euroed out Tookie blue
*ROLLERZ ONLY MAFIA*
Crankin the volume knob and hittin switches.
http://www.rollerzonly.com
bigger doesnt always mean louder. smaller boxes tend to be better for numbers on the mic, while bigger boxes are louder on the low-end. depends what you want louder
kicker zx1500.1 so about 1700 rms at one ohm
With that wattage I would put it in a larger box if building a new box isn’t that much of a hastle.
Can't say it WILL be louder but usually is.
X2
lemme do some math and check some airspace :)
EDIT: i wanna say it'll make a difference. those new dimensions give you a little more than double the airspace. dno your port size, so i dno the actual displacement. but for lows i would also maybe tune a little lower as well. i like to tune close to 30 hz myself
  • Who's Online   0 Members, 1 Anonymous, 4914 Guests (See full list)
