bumpincruiser Posted August 5, 2008 Report Posted August 5, 2008 ok so i finally got my system in my car. i was dissapointed to find out i cannot run my amp anywhere near full boar due to a wimpy electrical system. what is the best way to get my electrical good enough to power my amp no problem. keep in mind money is an issue. the less the better. now here is the story. the amp is a kicker zx1500.1 and it is hardly powering a audioque hdc312 in a 06 honda civic. now here is the bade i have 4 guage power and ground wire. i have the stock boattery. i have stock alt. no big 3 so what are my options and whats the cheapest and most output. thanks
bumpincruiser Posted August 5, 2008 Author Report Posted August 5, 2008 ok so i finally got my system in my car. i was dissapointed to find out i cannot run my amp anywhere near full boar due to a wimpy electrical system. what is the best way to get my electrical good enough to power my amp no problem. keep in mind money is an issue. the less the better. now here is the story. the amp is a kicker zx1500.1 and it is hardly powering a audioque hdc312 in a 06 honda civic. now here is the bade i have 4 guage power and ground wire. i have the stock boattery. i have stock alt. no big 3 so what are my options and whats the cheapest and most output. thanks or get a new battery or get one for the trunk
MECHMAN Posted August 5, 2008 Report Posted August 5, 2008 or get a new battery or get one for the trunk Sent you a PM. 1-888-MECHMAN www.Mechman.com [email protected]
Frozenbritches Posted August 5, 2008 Report Posted August 5, 2008 well, if you browse the forums look for people with other problems if you don't get a fast response...big 3 should be easy, check out that sticky and then see how much wire it is, mine is only gonna take like 30 bucks worth of wiring I think.. another battery which is 150...and you're probably gonna power them justtttttt fine...then you get a h/o the next time..which can be as low as 150-200 and would power twice that.. 2002 Jeep Grand Cherokee Laredo Hifonics Brutus Bxi2607D (FRIED...saving for ZX2500.1) 2 15" 07 L7's ported at 32hz Xplod POS for the MIDS, which are Memphis
