Wanting To Put A New Alt On The Car
Well i am wanting to put a internally regulated alternator on my 1963 impala but i need some help on doing that i dont have a clue on how to do that i am planing on making a custom mount for a newer alt my external regulator has 4 wires going into to the side of it and a wire from the alt to regulator and then to the battery any help thax.
And sorry if this is in the wrong spot.
Well i posted here is because i was thanking that mla would know more about this because they mess with alts and and stuff like this.
You don't need to do any re-wiring or making brackets. There is one that will bolt in and doesn't require any plug. PM'd you.
Your best bet is an off the shelf CS144 from a full size GM vehicle. Most of the sideways FWD Caddilacs from th mid 1990's have 140 amp CS144's. Rebuilt units are available across the country at any chain store - many with a lifetime warranty. There are some so called "one wire" units sold online, but replacment units are not easy to find if one craps out on a trip. The stock unit is easy to find, and will deliver an honest 140 amps for long periods of time.
You will need the mating plug for the CS144, which has 3 small terminals, and one larger. The only wire you need to worry about is the one in the cavity marked "L". You will need a 470 ohm resistor between the L terminal and your 12v switched ignition source. The resistor is there to limit the collector current delivered to the regulator. Do not put 12 volts directly to the L terminal, you will blow the regulator up.
We also make a stand alone module for this application, which includes the current limiting for the regulator. It comes with the mating plug for the CS144, and you simply connect the module to a switched 12v source.
The 144 is a bolt on for the stock GM mounts.
'Link
missinglinkaudio
The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
  • Who's Online   0 Members, 0 Anonymous, 1273 Guests (See full list)
