wasted ink Posted August 7, 2008 Report Share Posted August 7, 2008 http://fiberglassforums.com/showthread.php?t=672 good writeup by jon from epicenterdesigns Quote Wasted, Incorporated Up Front: Optima Yellowtop HU:Pioneer Avic N1 w/ 2007 upgrade Front Stage: MB Quart 6.5 comps Rear Fill: Infinity Reference Sub Stage: RE MT 18 Sub Amp: Undecided Sub Enclosure: 5.5 cubes tuned to 33hz Absolute Terminals SkyTec 5100RS 2-Way LCD Pager KnuKonceptz Wire My Build Log Link to comment Share on other sites More sharing options...
ALPINE408 Posted August 7, 2008 Report Share Posted August 7, 2008 ^^^^ fiberglass it a lot more work but it is cleaner Or 5 coats of pimer and 5 coats of paint will do fine Quote Have you ever had your woofers blown? Link to comment Share on other sites More sharing options...
IH8PunkRok Posted August 7, 2008 Report Share Posted August 7, 2008 if u coat the outside wit resin, sand, one more coat and then paint u have a very smooth base for paint and none gets absorbed into the wood Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build Link to comment Share on other sites More sharing options...
loganuf Posted August 8, 2008 Author Report Share Posted August 8, 2008 alrite guys....i was wondering, is there a brush or roll on paint that would be ok to use for mdf? i've used spray before and to me it seems harder to use, i know there has to be a brush on paint that i could use for this...im just not sure what it is? Quote 2000 Eddie Bauer Expedition: Alpine CDA 9883 2x 18" DC lvl 4 D2 10.7 cu ft box 33hz knu 1/0 wire amp: Kicker ZX2500.1 Kinetik Link to comment Share on other sites More sharing options...
Forevrbumpn Posted August 8, 2008 Report Share Posted August 8, 2008 if u coat the outside wit resin, sand, one more coat and then paint u have a very smooth base for paint and none gets absorbed into the wood ^^ exactly, thin coat or 2 of resin, sand smooth, then paint I usually dont do that, I usually just rhino line it, then paint the rhino line whatever color needed, THEN clear coat it Quote I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy. Link to comment Share on other sites More sharing options...
loganuf Posted August 8, 2008 Author Report Share Posted August 8, 2008 ^^ exactly, thin coat or 2 of resin, sand smooth, then paintI usually dont do that, I usually just rhino line it, then paint the rhino line whatever color needed, THEN clear coat it how much is rhino lining? ive heard its expensive? where could i get somethin like that? Quote 2000 Eddie Bauer Expedition: Alpine CDA 9883 2x 18" DC lvl 4 D2 10.7 cu ft box 33hz knu 1/0 wire amp: Kicker ZX2500.1 Kinetik Link to comment Share on other sites More sharing options...
GHOPPOMAN Posted August 9, 2008 Report Share Posted August 9, 2008 if u want is smooth without glassn...slicksand ftw! Quote Link to comment Share on other sites More sharing options...
01xtreme Posted August 9, 2008 Report Share Posted August 9, 2008 http://fiberglassforums.com/showthread.php?t=672good writeup by jon from epicenterdesigns if u want is smooth without glassn...slicksand ftw! I have seen Jon (epicenterdesigns) use both methods, and I think the slicksand workd out the best. 1 thick coat of fillerprimer, maybe 2 and you are good to go for paint. he just made a beer pong table for our cruise in and he sprayed slick sand and paint, and it turned our awesome. hopefully he will post pics tomorrow. Quote My System: Pioneer AVH-P3200BT 4-Dayton 7 inch reference series (front doors) 8-Onkyo 3/4 inch tweeters (dash) 1-Sundown Audio 100.4D (mids/highs) 2-18" BTL's (for now) Crescendo 3kwp (for sale) Complete rebuild coming soon... Link to comment Share on other sites More sharing options...
